1985 Merc 150<br />Been sittin up 5 years, rebuilt water pump, carbs, fuel pump, new gas etc. Cranked it today on the muffs and it seemed to run fine even idled pretty smooth after a while. Then I get this constant beep beep beep and I shut it down. Put my hand on the engine and its hot but wont burn ya. So I figure nothing major here. So I decides to check the compression. I cold tested it when I bought it and all cylinders about 105 or so. Now when I check it top left cylinder is about 15 psi. Very bad I say to myself. Others are 115 to 120. So I pull the head to see what the bad news is, and I don't see a thing. Cylinders are smooth as a babys behind. No broken rings, nothing. Turn the flywheel by hand observing cylinders, everything appears normal. Where's my compression? Oh yeah, gasket if fine.<br />Thank you one and all for any advice...Dave
