rick3452
- Oct 26, 2010
- 282
Back to my coolant loss. I believe that i may be losing coolant into the cylinders. The reason i think this is happening is recently on first start of the day the starter almost sounds like it binding for a second. Then starts and runs perfectly and will restart the rest of the day. I replaced both manifolds and risers about 1 year ago and used oem gaskets. The oil is clear and no other signs of leeking. Could it be internally between the riser and manifold and should i torque the bolts a bit more? Closed system. Ser. 0m012817. Carbed. Bravo 3
Thanks very much. Rick
