Which antifreeze?
geer3zpv
I have an old (1966)restored MFG 16' Westfield with a 60 Hp I/O. Last year, to winterize it, I put the "earmuffs" on the outdrive with a short hose and a funnel. A buddy poured a nontoxic antifreeze thru the funnel for about 2 gallons worth, then I shut off the gas, let the engine stall, and left her for the winter. Everything was fine in the spring, but I noticed some gelling of the antifreeze around the water pump impeller. The impeller is at the top of the outdrive. Is there a nontoxic antifreeze that will not react with the alumiumin components in the engine? What do you think of this winterizing process?<br />THX, Mike
andrewgroup
Re: Which antifreeze?
search this board for posts within the last 30 days and use winterize as the keyword. I've commented exntensively on my procedures and others.
crazy charlie
There is always a little gelling of any antifreeze I have ever used I mean a little.How much are you talking about?????Charlie----By the way,I stick with the old fashioned green stuff.
