Which Battery Switch to get?
clattin
I have an 87 Chris Craft 187 LTD BR that has an electrical short somewhere that we haven't been able to identify (without completely tearing it apart). I think I'm just going to install a shut off switch so that the battery isn't getting drained while its just sitting. I also thought maybe I'd get a second battery for the boat as a "just in case". Which switch should I get and how do I wire it all together? I would think that I would just connect both batteries to whatever switch you suggest and then I'll select a battery to run off of or put it in the OFF position when the boat isn't in use.
I was planning on buying something at my local West Marine.
Thanks!
Chris
bruceb58
Perko or Blue Sea 1/2/Both switch.
To isolate which of your circuits is drawing down your battery, take one of the battery cables off and put a multi-meter between the battery terminal and the cable in current measuring mode. Start pulling fuses until you find the circuit that is drawing down your battery?
If you have a stereo installed in your boat, that would be the first one I check.
