1985 Mercruiser 120 hp.
# A492171
Aplha outdrive
Which engine coupler came on this engine ? I believe mine is bad !
You should be able to see some splines when pearing up thru the gimbal bearing correct ? I am preparing to slide the motor forward, BUT want to make absolutely sure before I proceed !!!
Thanks all,,
# A492171
Aplha outdrive
Thanks all,,
