Which fuel line?
alldodge
My guess is since there were 2 different carbs used with a break by serial number, then depends on which one was used. This isn't going to help because they don't say which one works with the other. May Fun Times can assist
lister
The notes on the T says 3.0LX - 3.0
notes on the non T says the same + manifold with endcaps. Whats an endcap?
Are they talking manifolds with removable ends? I havent seen one that doesnt have removable ends. Either way whats the difference to the fuel line?? weird
dimensions looks different too but which one do I get , hellif I know.
maybe ill just use a generic flexible one or a brake line ;(
alldodge
End caps are removable manifold end caps.
Break lines work just fine so long as your not in salt water area
lister
Thanks, just freshwater here so maybe thats simpler and cheaper
last question as im trying to avoid making this electric pump work, what are the differences between a pump on an 84 and a 92?
Might the arm on the pump be too long and the cam might smash it as it comes around? Seems like theres a big area for it to hit
i suppose another problem might be if the correct one is an "upside down" pump and the one I have from my 84 is an 'upright' one
