auro2tango
- Aug 19, 2017
- 12
So my primer bulb on my 94 Force 40 will not stay firm, it fills the filter but i can easily squeeze the bulb for an indefinite amount of time. I have a complete gasket set for the entire engine, i recently rebuilt the carb and fuel filter and there is no gas/oil mix leak that I can see, but i clearly have pressure loose somewhere. I believe I narrowed it down to the headgasket, fuel pump gasket (the one behind the fuel pump cover), Transfer port gasket, or the drain reed gaskets. Im most likely going to replace them all, but your 2 cents are worth every penny.
