highpowerdad
- Feb 5, 2020
- 90
2005 SX and 5.0 GXI, Which Grease should I use when reinstalling the outdrive? I was expecting a THICK sealing grease, but the shop manual said "Apply a light coat of Volvo Penta Grease P/N 828250 to tapered end of pinion bearing carrier." I have 21347121, which is the same grease in a larger size...it looks just like regular bearing grease....not a thick sealing grease. What seals the bearing carrier to the bellows so no water gets in the bellows? Is it just the fit-up of the carrier to the lip of the bellows? How do I make sure that water does not leak into the bellows? Do you all do what the manual says or something "else"?
Thanks
Scott
Thanks
Scott
