Which ignition system do I have?
texasvet54
I have a 1999 Mercruiser (S/N 0L060433) with a 5.7L engine and I'd like to know how to determine which ignition system I have. My Mercruiser Service Manual has quite a bit of information about a Thunderbolt Ignition System. Does that sound right given my year and s/n?
Thanks,
texasvet
Re: Which ignition system do I have?
Ayuh,.... I would Guess you've got a T-Bolt V ignition...
achris
More fish than mountain goat
That number is coming up as a 1998, 5.0L Bravo, not a 5.7L!
Don S
I get the same thing as Chris, and yes it has the Thunderbolt V ignition system, and you should be using Merc manual #24. Is that the one you have?
texasvet54
Where did you find that info? The site I used said "5.0/5.7 Alpha and Bravo Gen+ " when I entered my serial number.
Thanks,
Texasvet
Don S
You must have been on a parts lookup program. "5.0/5.7 Alpha and Bravo Gen+ " is the engines covered in that catalog, it doesn't tell you exactly what engine you have.
