Which impeller
ashy
Hi
Can anyone help.
I don't know which impeller I need. I have a 4hp evinrude model number e4brcta serial number b016915. Also do I need any gaskets etc when I replace it.
Many Thanks
Pete
waynehol
Re: Which impeller
What year is the motor? Are you sure about the model number?
Vic.S
Re: Which impeller
1983 model.
no gasket but worth dismantling to see if it is worth buying the complete repair kit
Also surprised a bit by the model number. Are you in the UK? You are aren't you?
Outboards direct ( aka Oakley Marine) in Brighton or Willsmarine in Kingsbridge, Devon are both good for spares.
Quote the model number and they should be able to sort you out.
I think the impeller number will be 0389576 but check
ashy
Re: Which impeller
Hi,
Thanks for your help. Yes I am from the UK could you tell by my accent?:D
Cheers
Pete
Vic.S
Re: Which impeller
Sometimes one can tell by the words people use. Petrol instead of "gas " is a dead giveaway.
Often people with Belgium made engines are in UK. This time it was because yours has an internal fuel tank.
Anyway I looked at your past posts and discovered you were asking for Uk part nos for a Suzuki1
Put UK as your location in your profile then we dont have to go through this Sherlock Holmes procedure :D
BTW you'll find exploded diagrams at http://shop2.evinrude.com/Index.aspx?s1=89e34e62ef04b87bb960b2700e2260f1&catalog_id=0&siteid=1
even if your model number is not exactly listed
