daydreamer1252
- Aug 7, 2007
- 212
There are so many options for the types and weights of ?glass. You can do it so many ways and probably have good success with it. Very confusing! A search brings up many more hours of useful and confusing/confounding opinions.
New deck. ? exterior plywood. Want to glass/poly resin both sides. The glass is to hold the poly together to alleviate cracking/leaking issues, not necessarily to make it strong enough to drive a truck on.
What ?glass material is necessary?
Glassing inside of transom (I/O). What material? Glassing transom to hull sides and bottom?
Is there a common material that will do all of the above without requiring 3-4 different weights and styles to be found and purchased? and remnants be around forever?
I know that a ?glass tape is the easiest most practical for the deck joints and deck to hull joint, I think, don?t I??
What can be added to the poly resin to S__L __O__ W it somewhat in 95 degree heat?? I'm not as small or fast as I used to be!!
Thanks again for all your considered wisdom and help.
