Which power steering hose???
SandyBoat
Following on from my thread about how to remove the old high-pressure power steering hose, my next question is which part number do I need to replace it?
The engine is a 2001 4.3EFI serial OMO98359 and I have found two different part numbers that look like the replacement hose:
32 806222 16 HOSE
and
32 862878 PRESSURE HOSE
But the pictures of the hose show three different types, not two. The difference seems to be the fittings are either both right angle fittings, in the same direction, or at 180? to each other The third type has a right angle fitting at one end and a straight fitting at the other.
I need the fitting with two right angle fittings in the same direction, which appears to be 32 806222 16. Can anyone confirm this before I order it?
Thx
Don S
Re: Which power steering hose???
Item #11 in my drawing below is the pressure hose. There are two versions of it as shown by the image below it that has the PN's in it.
attachment.php
SandyBoat
Thanks Don. I have ordered the part 32 806222 16, but they tell me it doesn't look like the part in the image above, as it has a straight connector on one end and a 90` connector on the other. Who knows, but I just hope it fits.
