Re: which prop do i need
Look on the prop there should be a number on the barrel or under the prop nut.
Then tell us the length,approximate weight,style of boat.Your typical load and activities.Selecting a prop is like picking a single gear on a car to do everything.
Only on a boat if you pick the wrong size prop It won't perform right and if it can't operate within its designed rpm range it could develope premature mechanical problems.
There could be 4 or more sizes depending on the application.
