Which starter repair kit?
Alby1
I have a 1984 Mercury 50. The brushes went out of the starter, due to water getting in somehow. The starter is a Mercury Marine # 50-73521. I tried to find the repair kit here on iboats.com but got confused when I seen the part that looks like mine but, it said Arco repair kit and there are two of them. I read somewhere that Arco repair kits won't work on the starter I have. I want to get the repair kit that has the brushes and the end bell. Can anyone tell me what kit will work or where to find one? :confused:Thanks Much
Alby1
Re: Which starter repair kit?
OK, went there and all they show is a brush kit , no end bell. It also says the kit is for a MERCURY MARINE 75384, not a 73521, and there was no other listings. Still stuck.:(
Laddies
Banned
Go here first and ck the intechange your started is a 5379--http://www.arcomarine.com/xhtml/Cross%20Reference%20Outboard%20Starters%201.html
take that number and go here--http://www.arcomarine.com/xhtml/Outboard%20and%20PWC%20Marine%20Starters.pdf
then look on page 9 lower left corner and theres your starter and end cap assembly
Alby1
OK, I followed your instructions, and thank you. Also,I went the direct route and called ARCO to find out if the story I read about ARCO products not working with Mercury Marine starters and they said that all there parts are manufctured to OEM spec's. Thanks for all your help, I'm a little more educatated today.
