Which timing marks?
Buds Dad
1986 125 force has 1 mark on flywheel for tdc and 3 marks approx 2.5" to the left from tdc mark, which mark should i use?Prestolite ignition
roscoe
Re: Which timing marks?
Page 156 of the CLYMER manual if you have one.<br />The marks are 28*, 30*, and 32*. <br />The mark closest to TDC is 28*.<br />Set tower shaft to full throttle, use 28* at engine cranking speed for your motor.
