Absolutbost
- Sep 6, 2006
- 14
Which model tiny tach do i need to use to check rpms on a johnson 9,9?? the 2c is used on engines with one spark firing on each revolution of the crankshaft, or on 2 cylinder engines where the cylinders fire 1X per revolution. Is that the one I need? also is there some other way to check the rpms?? thanks for your help
