Which would you buy? Same boat 2010 vs. 2011
  • Total voters
    4
  • Poll closed .
USN8303
Key Largo 160 CC .....all things else being equal. If you think the newer one is preferrable, how much more would you pay for that version?
2010 with Yamaha 50 HP 2 stroke with 23 gallon internal tank (prone to fuel contamination problem through vented cap, but modified by dealer with ventless cap and side mount loop vent)
or
2011 with Yamaha 40 HP 4 stroke with 15 gallon portable tank that sits under the center console.
Lrider
Re: Which would you buy? Same boat 2010 vs. 2011
The biggest problem is where do you put all the fuel you need to play all day-the externals take up a Lot of floor space, especially a 15' 10' boat. I would rather put in a sophisticated water separation system than loose the acreage. mine is 17.5 ft and has a 65 gal tank wheeee. the fix should be great
