topdeadcenter
- Oct 27, 2008
- 4
Hey guys hope all is well on the water. I'm new to the site and I have been browsing around to see if anyone has already answered my question but no luck finding it yet. I have a 07 Grizzley Tracker 1860 SC powerd by a 2007 50hp Mercury EFI 4 Stroke. From the factory the prop was a Solace aluminum 11.1x14 which seemed to work good with two guys and minimal gear in the boat but since I also duck hunt out of this boat I often have alot more weight in the boat at time. Well the first problem was that when the boat was loaded down it wouldn't get up on plane very fast at all so I wasn't really happy with the performance so I ended up doing some research and decided since I needed a new prop that I would go ahead and play with prop sizes a little bit. Well I ended up buying a quicksilver black diamond aluminum 10.75 x 12 which is was all the sites recomended with the weight that I would have factored in between minimum and maximum weight I would have in my boat and they all recomended this size prop. Well I installed the prop just like my owners manual says applying 55ft/lbs of torque and adding a marine grease to the prop shaft prior to installing the prop. Took the boat out to the lake yesterday to test the prop out and it performed really well. I lost about 1mph but gained a massive amount of hole shot which is what I was looking for to begin with. The only problem i'm having is that when I engage the prop with the motor trimmed all the way down and accelerate to trolling speed approx. 2-4mph I hear a humming/whistling noise coming from the motor but when I give it gas it will quit or If I am still moving at trolling speed and trim the motor up a few inches it will quit. I'm really confused about what this could be or if this could cause any permanent damage to my motor. I was thinking that maybe I could bump it down to 50ft/lbs and add more grease to see if that would take care of it but I dont think that is my problem but I haven't tried it yet. I do know that when the old 11.1 x 14 was on it didn't make any noise. What do you guys think it is and what should I try to remedy this problem. Thanks a bunch guys for any help in the future and be safe on the water. Oh and the last thing is that i'm almost positive it is coming from the prop/propshaft becuase this noise only occurs when in gear. The noise also kinda sounds a little bit like a really quiet surpentine belt that is wore out or lose if that helps any. Ok thanks for the help guys.
