I'm trying to identify some Yamaha 40hp carbs I bought for my 1986 40hp three cylinder. My Clymer Yamaha outboard shop manual only goes to 1989 or up to carb number 6H410. These carbs are marked Keihin 6H411-FA19 so I'm guessing at 1990 or 1991. Can someone look in a newer manual and give me the year and specs for these carbs? Also, these carbs do not use a choke system and don't have the butterfly in the front of the carbs. They use a type of enrichner that squirts fuel in the manifold behind the carbs. If someone has this type of setup can you tell me where the fitting is so I can install one on my old engine. Finally can someone confirm that I have an 1986 engine. The serial number is 40ETLJ 6H4L552918. My manual only tells me where the number is located but not much else. Thanks for any help.
