Who Would Recommemd Edelbrock For Bb Merc
cdiamond
I've got a 7.4 merc
The weber carb is shot looks like it ingested some salt water
Considering a edelbrock 1410
Wondering who has had good or bad results
Thanks
bajaman123
Re: Who Would Recommemd Edelbrock For Bb Merc
It's a good unit. Combine it with a Performer manifold and you will be pleased with the results.
Years and years ago, I put the 600 cfm version with a performer manifold on a small block Chevy powered Bayliner (came stock with a 305 2 bbl) and it lit that engine up. Was able to go up in prop pitch and maintain rpm, picked up about 6 mph on top end with a better hole shot.
I can't say enough good things about my experience.
Just make sure you get it jetted right if you do get it, put it on, make some runs, check your plugs, etc. Of course you'll have to do this with ANY carb for that matter.
Ayuh,... It's the Exact Same Carb,.... except for the Name on it....
wca_tim
I am currently running one and like it fine. It took some playing to get it dialed in on my small block. They have a somewhat undersized idle circuit and can take some playing sometimes to get rid of an off idle lean spot, but it's not that hard to figure out if you run into.
