sidenberg
- Mar 2, 2010
- 206
The wiring diagram in my Baylinner manuel shows 1 #10 ground wire that runs from the negative battery post to the negative connection at the fuse block behind the dash and then another #16 ground wire in the harness running from the motor ground connection to the negative connection at the fuse block behind the dash. I discovered this after finding the ground wire in the harness had been disconnected by a previous owner after it had melted. Is this wired with 2 separate grounds for added protection in case one fails, as mine did, or is there another reason?
