Why can't I go fast ?
cranchi
Two weeks ago I unwrapped my boat after the winter and started her up with the ears on, no problem, she idled and I ran her up to operating temperature. <br />Last week I put her on the water, ran her up river slowly at around 1000 - 1500rpm to warm her up and make sure there were no problems all seemed OK so I gave her some throttle to get up on the plane and she died on me after about 2000rpm. Started OK again and idled OK so gave it another go and died again.<br />Engine is a volvo 431A - AQ205SP V6 4.3<br />The problem got progressively worse and in the end wouldn't even sustain tick over. Manhandled her back onto the trailer and gave up. Any ideas out there. Thanks.
WillyBWright
Re: Why can't I go fast ?
Welcome to iboats.<br /><br />I'd be looking for water in the fuel.
phatmanmike
yes, water in the fuel. do you have a fuel/water seperator? if you dont, you should. i do.<br /><br />drain out some of your fuiel, like a gallon or so snd check for water.<br /><br />this is a fairly common thing after winter storage. cold, then not cold, condensation...etc etc etc
cranchi
Thanks guys, just wondering would it be best to drain out all unused fuel at end of season.
walleyehed
Water would have killed it at Idle earlier as well as at a higher throttle setting.<br />Sounds like a possible fuel delivery issue to me...<br />If the boat was stored properly, the tank was full, and if it was, there's no room for condensation.<br />You don't mention si or Gsi, so I'm assuming carbs??? If so, I'd be looking at a fuel pump problem or even a vent-line plugged.
JB
Howdy, Cranchiboy.<br /><br />Welcome to iboats. :) <br /><br />It might help to post in a troubles forum, and one that covers Volvo 4.3 I/O engines.<br /><br />Moving to I/O.
LubeDude
"Why cant I go fast"?<br /><br />When I read this I wanted to post.<br /><br /> Because you dont have enough money"! <br /><br />But I held back. :p :p :p
sue5878
Hi Cranchiboy,<br /><br />I had this problem a few years ago, turned out to be the coil breaking down.<br /><br />Neil.
waterone1@aol.com
My first thought is also fuel related. Did you store the boat with a fuel preservative such as staybil added to the tank ? You could have stale gas. Does the gas have any strange odors ? If no strange odors, and no water in fuel, you may want to change all fuel filters, including the one in the carb (if equipped).
'60Buickrod
Could be your fuel filter. I've had that problem on my Buick (it's kinda like a boat but doesn't go in water :D )
