Why does engine stall going from high speed to idle ?
bobgritz
Whenever I cut back to idle speed instantly or abruptly (from anything above 1/3 open throttle) my 15hp Johnson stalls out.
But, if I throttle back slowly, it comes down to an idle without stalling.
Although I always try to idle down gently, half the time you need to simply cut your speed quickly and the engine dies!
AlTn
Re: Why does engine stall going from high speed to idle ?
how low do you have the idle speed set?....in fwd, motor hot, does it idle well, or gasp and jerk?...I'd try increasing the idle speed to see what that yielded....~600 rpm in gear at idle
