Re: Why have i lost 5 to 6 mph ?
GaryB.........<br /><br />I have a 1978 Campion Cuddy Cabin, (Canadian built), that I bought with an 85hp Johnson. the boat would top out at apx. 29 to 30 mph. I wanted more speed out and found a sweet deal on a low hour 150hp.<br /><br />While doing the engine change over, I found the transom was rotten and saturated with water. I pulled the flooring up to access the transom to replace and found all the foam under the floor was totally saturated with water. The boat did not leak one drop, but the water damage was due to the build up of rain water and water from washing it, etc, over the years, by the preivous owner.<br /><br />After replalcing the transom and refoaming the hull, I sealed the floor and took it for a test ride. The boat sat up at least 2 inches higher in the water and my speed increased by apx. FOUR MPH. and with greater handling, still uning the same 85hp motor.<br /><br />The soaked transom wood and foam had added several hundred pounds to my boat, causing the decrease in speed and handling. <br />It might be worth your while to check the foam and see if it holding water. This might be be the cause of your speed loss.<br /><br />The acutal cause of the water saturation, was the lack of resin saturation on the glass cloth, especially at the base of the trasom, near the drain plug area. This was a factory defect from the day it was built.<br /><br />...Bob in Calif...
