Why Is My Battery Post Hot
JDusza
Ensign
I'm putting a rig away for a friend and noticed his battery connection on the negative side is extremely poor. The ring terminal is basically sitting against the post. In addition, I found that when I run the starter the negative battery post gets unbelievably hot. In fact, today I got a pretty good burn off the post.
This is definitely not a good situation. What could be causing this hot terminal?
J
GA_Boater
The battery connection. Heat is caused by poor connections. Fix the negative connection and while you're at it, clean the positive side. Probably will fix some other troubles by doing those two things.
crb478
A good tight connection is critical. Heat is a product of resistance, and a loose fit is resistance. Good clean connections will fix it.
H20Rat
I've seen connections get hot enough to actually weld themselves together. Ironically once that happens the problem is fixed! (of course, other times it might burn the entire thing up, luck of the draw.)
