I was working behind the instrument panel of my pontoon (when I forget to turn off my master battery switch!) I sparked the red wire to ground and lost power to both the instruments and the ignition feed. I checked and replaced any of the battery cable and engine blown fuses (one was blown) but I still I have a dead red wire to the ignition switch. All four fuses on the engine test fine. Battery cable fuse was replaced. As a test, I've jumpered from another good power lead to the red wire terminal on the ignition switch and now the engine starts and runs, so the red wire from the engine to the ignition switch is good and I have all other power (gauges, etc. but of course my lights master power is now energized with the switch off.) So it seems like the battery line to the engine is bad (why now?) or there is another fuse somewhere or something on the engine battery connection is toast. Ideas? Engine: 2005 Mercury 60hp ELPTEFI on a 2005 Monarch pontoon. Thanks. I'm stumped.
