I am adding a kicker to my boat and am deciding weather or not to use an outboard bracket to mount my kick, or just mount it on the transom. My transom is wide enough to mount a kicker on, add the kicker shaft is long enough it would be in the water. I think I could hook up a steering rod from the main outboard to the kicker and be good to go. But my mechanic tells me I need the bracket and a steering rod that straps on the outboards above each cavitation plate to work smoothly. I would like to save some cash but want it to work well.<br /><br />So.. what do you all think?<br /><br />thanks
