I recently bought a 2001 25HP Johnson J25TVL3SIE. It wouldn't idle unless the choke was pulled out halfway. Seemed good a WOT (when I water tested it). I Cleaned the carbs, replaced the plugs and fuel filter. I also bought a Seloc repair manual. The carb setting in the book said .390" above carb cover, but the screw comes out the side. WTF? So I got it to idle nice in a barrel. (6 turns out) does this seem right? Water tested it again and no power at top end, but runs good/not bad. Wide open feels like half throttle.
