Wide open throttle timing
Beatyouthere
I just replaced the timing trigger and the stater I synced the carbs and timing and checked and adjusted the pick up timing do I have to do anything to wide-open throttle timing and if so what's the best way to do it
jimmbo
Besides posting this in the wrong Forum(I sent a note to the Moderators to move it), You have not provided any Info as to what Engine is involved.
What Service Manual are you using to guide you thus far?
Beatyouthere
I apologize for putting this in the wrong place I am new to the group or forum it is a 1987 Johnson 200 hp V6 looper motor it's running fine I change the stater and the timing trigger synchronize the motor and set the pick up timing according to the book But the book give information on Wide Open throttle at least not that I could find as far as adjusting after the timing trigger being replaced
