1998 40 Hp Evinrude shift rod length . 21.38 was what i found but it will not go into reverse .
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #1 1998 40 Hp Evinrude shift rod length . 21.38 was what i found but it will not go into reverse .
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 38,484 May 21, 2023 #2 Try 21 15/61"-----21.937-----Where did you find 21.38"
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #3 everything on 40 Hp. 1998 Evinrude shows' that Attachments 52475 gear case 1998.gif 118.5 KB · Views: 2
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 38,484 May 21, 2023 #4 I know what the parts look like.-----Where does it show the 21.38" for your motor?----Model # of your motor ? Last edited: May 21, 2023
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #5 Service Manual 40-90 HP Gearcase [Shift Rod Adjustment] | Crowley Marine www.crowleymarine.com this is the link to the adjusting and measurements for my 40 Hp. Evinrude E40TLECR di that and will not go in reverse
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 38,484 May 21, 2023 #6 It covers different models.----What model did you set it for.
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #7 every thing i found says to set it at 21.38 or 21 3/4.
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #9 i will set it at that and see what it does later when it cools down . hot out side where i am at . Thanks from So. Ga.
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 38,484 May 21, 2023 #10 Post #5----Click on that.----Then see ---tech articles-----Click and look on page 55 I think.
P papasage Senior Chief Petty Officer Joined Jan 12, 2003 Messages 785 May 21, 2023 #11 21 15/16 it is going into both F and R. Thanks for the information . my tag has 1997 but when i ran the serial # it came up a 1998. Attachments papasage boat.jpg 92.6 KB · Views: 1
