sunsetridge1
- Aug 18, 2008
- 8
pls. help. I am replacing my prop for my 1989 celebrity mercruiser boat. i cannot find my prop size on the old damaged prop even after removing. what size and pitch prop do i need?
They pretty much just go by pitch these days mostly, and I hazard an estimate at about a 19 pitch. That would probably be a 13 3/4" x 19" in the older nomenclature.What pitch n size do i need?
I have a 21ft 199 SE cuddy celebrity mercruiser. Do you think 19pitch still would work or what would you then recommned?
Yes, a 19 should be a very good all-around prop for that boat. A 21 will be slightly faster, but harder to get on plane. If you usually run light then the 21 will work, heck a 23 might even work but probably wouldn't be ideal. Personally I would go with the 19. All the theory in the world is fine for pencil-pushers, my advice is based on a fair amount of real world experience.so 19 pitch is what u reccomend? now does higher pitch means more speed or is it lower?
