jbjennings
- Jul 18, 2007
- 3,903
A friend got himself a junkpile 4.5hp mercury and brought it to me to see if I could fix it for him. It had a bad coil but I replaced it and it has good spark, I've cleaned the carb and tried squirting fuel into the carb. throat and cylinder. It won't even try to fire. I finally tested compression and it had about 65lbs. after several pulls with a rope wrapped around the flywheel. I've had johnsons that would crank with that low compression but I'm thinking the mercury won't. It should have about 125lbs., right???
Any ideas? The reeds looked good, too.
thanks,
JBjennings
thanks,
JBjennings
