will a 89-94 force prop fit on 79 chrysler?
slikrx
As per the topic title does anyone know if a 15 spline prop from a 89-94 150hp force will fit on an 1980 chrysler 115. They are both 15 spline and i know the force has the exhaust thru the hub and the chrysler doesnt, but that doesnt make a difference as the current prop has the exhaust holes and it fits and works fine. Any help is appreciated! :)
Frank Acampora
Re: will a 89-94 force prop fit on 79 chrysler?
Yes, the prop will fit and no, there is no performance difference between open hub and closed hub with tailcone. That is assuming the same design prop with the same pitch. Different design props will perform differently--for example a Ballistic 21 pitch prop will lower RPM by about 500-1000 over the stock Chrysler stainless prop. A vortex aluminum will lower RPM by about 400 over the same stock Chrysler aluminum prop.
MickLovin
Master Chief Petty Officer
So what pitch are you looking at with that new prop, 19?
