spacecoyote
- May 12, 2010
- 5
I have a 1989 Force 125 on a 16'7" Aggressor bass boat. The motor was supposedly rebuilt by the previous owner, but there are some telltale signs that it could have been a hack job. That aside, the motor seems to run smooth. I had the carbs rebuilt, so I'm pretty sure there is no problem with the motor getting fuel. The problem is that when operating at 5500 rpm, I'm only going 25mph. I can't even get the boat trimmed, it just plows. I can open the throttle even more and get up to 6500rpm, but I don't keep it that high. Even then, the boat won't get up on it's pad.
My question is, would a motor with bad compression or a missing cylinder, even get 6500rpm? Is there something else, motor-wise, I should check? I am trying to rule out the motor before I consider waterlogged foam, prop selection, or transom height. It just seems that even with a heavy boat or too little prop I should be getting better than 25mph.
