Will a Merc '77 IL6 gearcase fit a '93 Merc V6
Chris1956
I have both of the subject gearcases on hand. I have always heard that the L6 gearcases would fit a V6. The driveshaft dia and splines seem to be the same. The driveshaft is a bit shorter than the V6. The L6 gearcase sems to be a bit different than the V6 gearcase, but by 1/8 to 1/4" as measured with a ruler.
Has anyone done this swap?
Dukedog
it will bolt up by removing tha front stud but its not advisable ta run it ona V6... tha driveshaft is "about" an inch (give or take) to short.. closer ta 3/4 of inch.. won't last...... we use ta run 'em but we had a 16" clamp/trim/brackets with a cut and resplined driveshaft, low water pick up... this would make sure tha driveshaft seated completely in tha crank on "slightly" modified 225's in early 80's... that was in tha days prior to tha 15" factory stuff hitting tha market....
