I need a little help please. I bought this boat a couple years ago and I have had an over-rev problem since day one. Here is what I have.... 1) Performance issue you are trying to correct. Hitting 5500 rpm's at about 1/2 - 3/4 throttle, over-rev sensor shuts it down but doesn't kill the engine ( turn off the engine, starts right back up then runs fine as long as you watch the tach) 2) Current prop manufacturer, model, aluminum or stainless as a minimum. Aluminum 3) Current prop diameter and pitch (required). 12-1/2 X 15 X 305 all the numbers that I could find 4) Wide open throttle RPM and speed with an average load (very helpful). 5500 at 1/2 - 3/4 throttle , 21-22 mph 5) Engine/drive make, model, year, and HP Evinrude , E40TTLEUC , 4/97 , 40HP 6) Boat make model, year, length and weight. Bass Tracker , Pro 17 , 1989 I know that this motor was put on about a year before I got it. The last owner said that it was always like that. (doesn't make since) Do you think that by going to a 12x17 prop would fix this problem? I'm lost. I'm open to any advice offered. Thanks
