will a starter from a AQ130C fit on a AQ-125B
90skichallenger
Re: will a starter from a AQ130C fit on a AQ-125B
Yes it should. The main diff in those two motors was carb setup. So the bottom end parts should swap out
rabidfish
Some Volvo (bosch) starters had threaded holes in the starter housing, others used through bolts. Otherwise no difference...
