will accetone remove epoxy blush?
lime4x4
I would like to use accetone to remove the epoxy blush then scuff and re-wipe with accetone.
Woodonglass
Re: will accetone remove epoxy blush?
I would just use a wet scotchbright sponge from a bucket or warm water and a little sudsy ammonia. It does not need to be sopping wet. Use the scotchbright side first then use the sponge to dry the area and frequently clean the sponge in the bucket-To get sanding right away, use paper towels to finish the drying process.
