Will be replacing my Temp Sender SIE-5897 ON MY 1989 4.3LX
HPLou
And I would like someone to confirm if I need to put any sealant such as Grease, LocTite on the temp sensor threads before the install.
Thank you.
Ayuh,.... Use whatever sealin' compound Paste ya want, just don't use tape,...
It needs to be properly Grounded,....
hzxlvf
I just did mine. I used Loctite High Temp Sealant. Little tube cost half what the sensor did. No leaks and it's grounding
HPLou
Great Thank you for the replies.
hzxlvf
What ?Loctite P|N have you used?
HPLou
Thank you achris for the info.
And, Also thank you for your SUPER good videos. They are very helpfull.
HPLou
