Will I be able to ski behind this boat?
lilcane88
Re: Will I be able to ski behind this boat?
with 140hp it should get you out of the water just fine
tashasdaddy
that is an old 140 mercruiser probably, the trihull and that engine. it might get you out of the water. also if you buy from Lanier, check the boat out 100%, they do not have the best reputation.
Moody Blue
The photos show it as a 120hp not 140 as the ad states.
A 20ft trihull boat, an 8ft beam and a tired 120HP it will be marginal to pull you up on two ski's and a struggle to pull you up on one.
kenmyfam
That's a lot of boat for your 120 hp. If it is in good shape then you should be able to ski behind it but there are better outfits you could find if you are serious about water skiing.
26aftcab454
I think you will be disapointed as a ski boat- it looks too tired - should be ok just riding around my $0.02--keep looking
