Hi all, just woudering if a 1993 15hp lower leg will fit onto a 2000 model both short shaft. Thanks
S slate1234 Petty Officer 1st Class Joined Jul 1, 2012 Messages 210 Jul 17, 2016 #1 Hi all, just woudering if a 1993 15hp lower leg will fit onto a 2000 model both short shaft. Thanks
flyingscott Fleet Admiral Joined Apr 8, 2014 Messages 8,159 Jul 17, 2016 #2 If they are both 2 strks I believe they will best bet would be to compare them
S slate1234 Petty Officer 1st Class Joined Jul 1, 2012 Messages 210 Jul 17, 2016 #3 the problem is mine is letting in water and there is on on fleebay quite cheep.
flyingscott Fleet Admiral Joined Apr 8, 2014 Messages 8,159 Jul 17, 2016 #4 Reseal your lower unit cheap usually means something wrong with it
S slate1234 Petty Officer 1st Class Joined Jul 1, 2012 Messages 210 Jul 17, 2016 #5 I was thinking that but there would be a lot of questions being asked on here, I was going to carry on using it and change all the seals this winter as a project
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 38,520 Jul 17, 2016 #6 If it is in good shape it will bolt right on.---Exact same units if 2 stroke.
S slate1234 Petty Officer 1st Class Joined Jul 1, 2012 Messages 210 Jul 18, 2016 #7 hanks racerone, flyingscott, I think I will buy it then
