will it work
lilb
Hi I have a rather unusuall question. I was wondering if a mercruiser series 1 lower unit will bolt up to a gen 2 transom? I already counted the splines and they are the same, as is the length of the shafts. iI just would like to know if there would be any other problems i would incounter.
The reason for asking is my gen 2 lower has a bad seal at the the drive shaft/ u joint, and being the holiday weekend all the parts stores are closed. I can borrow a friends series 1 for the day just to get out on the water for the day. Thanks in advance for your thoughts and/or input.
Bt Doctur
Re: will it work
Series1(Mod1), R, MR, Alpha will all interchange
Gen II will only interchange with another GEN II
"gen 2 lower has a bad seal at the the drive shaft/ u joint"
What is it, upper or lower?
lilb
Re: will it work
it is the upper that has the bad seal. I was wonderin if the whole series 1 unit will bolt up to the gen 2 gimble hat with no problems
