Will my oil pan gasket leak or should I re-do it?
islandboy47
I'm putting together a rebuilt Mercruiser 3.0 motor and it's one of the older style ones from the 80's that has the 4 piece oil pan gasket. Two of the pieces are cork and two are rubber. When I put them on I put some Permatex Ultra Black on the block and some on the pan itself, going around the entire thing on both of them (after cleaning them with acetone). Then I let it sit for about 10 minutes, then I put the oil pan on and hand tightened the bolts down. After letting it sit for an hour I tightened the bolts down and now it's been a couple of days since then.
My friend, who is much more mechanically inclined than me, asked me if I put silicon or anything between the gaskets where they overlap, like when the cork goes over the rubber gasket for about 1/2" or so in 4 places. I did not do that. He is under the impression that we should remove everything and re-do it to make sure we don't run into any leaks, because replacing that gasket after the motor is installed is going to be much more of a PIA.
The thing is I'm really hoping to get the boat running within the next week and ordering a new gasket will delay this timeline. I wanted to get somebody's opinion here - how likely am I to run into issues here? I was thinking that because there isn't a ton of pressure inside the oil pan then it's unlikely to leak unless there's a pretty serious hole or weak spot in the gasket. Thoughts?
Scott06
I think you are supposed to trim the 1/2" where they overlap, not double them up with silicone in between. For me I would redo them as there is no way they can sit flat.
I would run it on the ground before you put it in it is easy to do and look for leaks
jimmbo
If there is any Doubt, it is far easier to redo it now, than once it is installed and running at the Lake, River, Ocean
islandboy47
That would make sense! I couldn't really find any info on using these 4 piecers anywhere, so was mostly just guessing.
flashback
Looks like the flange on the pan is bent now. You cannot over lap a gasket and expect it to seal. Trim the cork to fit and use a sealant at the joint.
tank1949
oil is cheaper than pulling motor. Hopefully, no rust on pan?
