Will Not Start Due To Grounding Problem??
chodie
1995, 75 hp force by mercury--My cd units are grounded and motor will not start. I can disconnect the black/ yellow wire and motor cranks and runs good. However I can only turn the motor off by reconnected the black/yellow wire to the cd units. How can i get control of when I want to ground cd units? This apprears to be a ground problem, but I don't know where. Any input appreciated. thanks
Frank Acampora
Re: Grounded cd units problem
Obviously the CD boxes are working. Thus: you need to check for a broken or frayed and grounding wire or the ignition switch is either defective or incorrectly wired. Let's not forget that the CD box ground wire may be connected to the wrong termination.
Barnacle_Bill
Make sure your emergency kill switch isn't activated too.
chodie
Re: Will Not Start Due To Grounding Problem??
The emergency kill switch has been removed. I have ordered a new one. Should the inlet and exit wire be taped and left open or should they be tied togeather for a complete circuit and taped? This is for a temporay fix until I install the new switch.
pnwboat
They should be left open or apart. If you connect them together it will ground out the ignition preventing the CD units from firing.
john from md
PNWboat hit it on the head. Your leads are probably touching and shorting out the CDI modules.
John
Lone Duck
Master Chief Petty Officer
Yep! You can also put a temporary toggle or push button from black /yellow to ground as a shut down till you get into the complete fix.
