Will prop work
7designs
Will a prop from a 83 mercruiser 140 fit a 77 mercruiser 120/140?
Is the lower unit the same?
steelespike
Re: Will prop work
If you check at the prop store here you will see that they appear to be the same number.Whether the pitch will work is another question.
7designs
Re: Will prop work
The diameter and pitch is exactly what I need.
I will go try to look it up in the prop store and educate myself.
Thank You
