Re: Will The Tires Fit?
KMK..........
If you do go with the P195-70/R14 size, your vehicle's speedometer will indicate 70 MPH, but your vehicle actual speed will be 75.5 MPH, compaired to your P175-65/R14 at 70 MPH. The P175-65/R14 doesn't sound like a factory installed tire size for your Escort, but I could be wrong.
The best thing for you to do is to look on your car's driver door or on the drivers door frame, with the door open, and see what the original tire size your vehicle came with, as shown on the Federal sticker.
Use the speedometer calibration calculator, I have placed below, to search match different tire sizes to get the most accurate speedometer indication and actual speed. I usually post this site once a year. It has many more calculation sites, for just about everything that need's to be calculated.
www.csgnetwork.com/speedocalibcalc.html
...Bob in Calif...
