1977 omc stern drive 235 hp 351W. Idles great, at about 1500 rpms, it loses power in the yard and in the water. I have replaced the plugs, wires, cap, rotor, points, condensor, rebuilt the carb, checked the fuel system . The filter is clear. I put the fuel line in a bucket of gas to rule out a stopped up fuel system, no difference. Timing is set at 4 degrees BTDC, points are at .018. What else can it be? Bad distributor, fuel pump??? All advice would be greatly appreciated!<br />Dan
