Will this fit?
tonyjh63
Anyone know if this prop will fit on a A1G2? Number is 48-72500-21.
And if it does fit, what do I need (hub kit, adapter, etc.) to make it fit? Thanks!
ScottinAZ
Master Chief Petty Officer
The part number is a Merc number, so should fit your drive. IIRC the gen 2 is still 15 splines, so any prop that fits the earlier gen outdrives and a good number of outboards will work. You will need a thrust washer and lock washer kit to mount, but if you have a prop on your drive that should be covered
tonyjh63
I have a Turning Point prop on now, with "hub kit" that has a hard rubber insert, thrust washer, castle nut, etc....
Scott06
The new prop u are looking at had the older style pressed in rubber hub so I believe you will need the thrust washer that fits that style prop. Don’t know the part number but would imagine a prop shop or dealer would know
