WinnerCougar74
- May 12, 2020
- 252
I have a 1974 135hp that runs ok. I know it's impossible to say how long it will run but the one area on the motor that seems bad is the prop bearing carrier. Is this normal looking corrosion? If I try to replace it is it likely to break apart? It seems brittle and there is probably corrosion inside that will make it real tough to get out.
