Will too advanced or too retarded cause overheating?
IcantDo55
Well I have replaced the Riser, water pump, thermostat, thermostat housing flused the block and cleaned out the manifold. Now I went to check the timimg and it was about 14* BTDC Wow! (yes I used the right procedure) Would this have caused my overheating problem under load? I backed it off to 1*-2* BTDC and than removed the jumpers and it jumped up to 14* at idle. Good right?<br /><br />Just checking of the 14* bast timing would cause overheating or would it have to be too much retard.<br /><br />1995 3.0LX
calwldlif
Re: Will too advanced or too retarded cause overheating?
Yes, to a point.<br />Tight valve lash also contribute to heat.<br />Enough to cause trouble? It is possible.<br />how probable? Usually not enough to be dangerous.<br />But it will be noticable.
tommays
Well a few degrees to much and you melting holes in pistons SO i would say YES<br /><br /><br />Have you changed the fuel filter in the carb ? i have found out the hard way it will lean out the motor enough to make a LOT of heat<br /><br /><br />tommays
bruceb58
Retarded timing makes an engine run hotter.
IcantDo55
Well tested it on the water today, ran great! <br /><br />Thanks fro everyones help!<br /><br />Moral...14* timing bad!
